FSO vs. Exclusive Fullscreen
TTT
Post by TTT » 21 Nov 2020, 10:25
MODERATOR NOTE:
Posts in this thread split and moved from this topic: viewtopic.php?f=10&t=7767
For Apex you need to figure out how to turn off FSE as well, it forces on now when you turn it off via .exe or registry.
Mine turned itself off the other day and I hadn't even done anything but when I reset the game it was on again, but the input lag difference is definitely noticable.
howiec
Re: FSO vs. Exclusive Fullscreen
Post by howiec » 21 Nov 2020, 19:17
TTT wrote:
21 Nov 2020, 10:25
You mean Disable FSO (plus other things) so that you are in FSE.
Mine runs in FSE fine and yes, I do notice a difference.
1000WATT
Post by 1000WATT » 21 Nov 2020, 19:57
howiec wrote:
21 Nov 2020, 19:17
TTT wrote:
21 Nov 2020, 10:25
What version of windows do you have? How do you understand that the application works in the FSE, except for your "feelings"?
howiec
Post by howiec » 21 Nov 2020, 20:27
1000WATT wrote:
21 Nov 2020, 19:57
howiec wrote:
21 Nov 2020, 19:17
TTT wrote:
21 Nov 2020, 10:25
Pretty sure FSE has been working fine for me since at least v1803.
I'm currently on v2004 (which I don't recommend if you use certain onboard Realtek audio chips because I get some stupid sound popping/crackling issues with mine that have been reproducible by me and others to only occur on v2004 - but HAGS is only on v2004 or later...).
I know FSE is working because there's a delay and the screen flickers every time I switch to or from the game to desktop, and the input-lag feel/difference is very noticeable and I can detect it 100% of the time with simple AB testing (well, really it's pseudo AB testing because I'm the only tester who randomly changes the value, and I have to not look too early and see the flicker...).
1000WATT
Post by 1000WATT » 21 Nov 2020, 20:29
howiec wrote:
21 Nov 2020, 20:27
Do you have 2 monitors?
howiec
Post by howiec » 21 Nov 2020, 20:30
1000WATT wrote:
21 Nov 2020, 20:29
howiec wrote:
21 Nov 2020, 20:27
Yes, PG259QN + PG258Q currently connected. Normally I'd do 3 but desk space is less cluttered for now.
1000WATT
Post by 1000WATT » 21 Nov 2020, 20:33
Download this app and run on a second monitor
https://drive.google.com/file/d/17g8Mk6 ... sp=sharing
run apex and take a screenshot. Similar to this one.
https://drive.google.com/file/d/1A8b3Ep ... sp=sharing
howiec
Post by howiec » 22 Nov 2020, 02:03
1000WATT wrote:
21 Nov 2020, 20:33
Apex doesn't show up in screenshot probably due to it being in FSE and the way Windows takes the screenshot or something.
But yeah, looks like it's in FSE.
In-game FPS cap is 251 as well.
1000WATT
Post by 1000WATT » 22 Nov 2020, 02:43
this is fse 100%
version 2004? I'll have to try. thanks for the information.
TTT
Post by TTT » 22 Nov 2020, 08:56
howiec wrote:
21 Nov 2020, 19:17
TTT wrote:
21 Nov 2020, 10:25
Yea I meant FSO not FSE. :D
How have you disabled it?
*Edit
Just saw your post, yea the black flickering happened when I was playing the other day so I knew it was off but then its just back on again, I didn't even change anything when it did go off.
I'm just running up to date drivers.
Are you just using the .exe tickbox to disable it?
