Hello
I get my new Samsung G7 27“ Gaming Monitor.
When I activate low input lag Model i get micro stutter. Anyone else with that problem? Monitor runs with HDMI.
I ordered a HDMI to DP Adapter. I thought HDMI causes micro stutter. Did an Adapter increase input lag?
Samsung G7 27“ Input lag
Re: Samsung G7 27“ Input lag
Define microstutter.
What OS you using and what's your CPU/GPU?
Also, do you run games in fullscreen exclusive mode?
Using a PS4.
Witz 120hz there is no micro stutter but when running on 60hz.
Monitor goes a Frame back and gehen forward. Thats micro stutter for me.
Did you solve the issue somehow? I'm experiencing the same problem.
I think that Samsung, as before, does not know how to make monitors. The cfg series had a feature - you had to manually select the refresh rate on monitor menu. Otherwise, there were double frames or stuttering, even if you select 60 in Windows, the monitor worked at 144Hz and caused a stutter.
In your monitor, there is probably also a choice of a refresh rate, I looked at the manual, I think this is the "game" tab ,refresh rate, put 60Hz there (you also need to turn off the freesync in the monitor menu, there was a choice)
English is not my native language, this is an online translator
