Yeah that really is not true. The computers at large esports events do not have highly optimized OS's and yet those players preform with minimal input lag. Those PCs are working properly and as the engineers that built those components intended. There are not an infinite number of bottlenecks, it just feels that way when you have electrical problems causing a cascade of issues with inputs. Yes you can mitigate some of these impacts (like you did with your super special roached out gaming PC) but at the end of the day its never as good as someone operating their PC at a place with zero electrically induced problems.Brainlet wrote: ↑31 Dec 2020, 03:55
Your "perfectly fine" is what other people who don't have other huge latency bottlenecks might consider "laggy". Latency isn't black or white, you don't either have it or don't have it. There always is latency, whether it's 1 picosecond or 1 second. All you can do is work your way forward and get rid of as many bottlenecks as possible.
I have an optimized gaming OS and without a single exception it ALWAYS feels infinitely better than my daily non-gaming operating system (compatibility), no matter at what time of the day or what day of the year I boot into it. They are PERMANENT latency reduction optimizations.
For example, if your monitor is affected by EMF of some random device and as a consequence increases your input lag, you can PERMANENTLY get rid of that specific latency bottleneck by simply moving said device far enough away.
I don't know what exact problem you're facing (apparently you don't either) but to assume that it applies to everyone and that everything other people do to mitigate a part of their latency is placebo is simply ignorant.
Modern day monitors and PCs are largely immune to EMF. Especially 60 or 50hz AC EMF. That article you refer to is speaking about RF, and the TV there is a particular instance of a terribly designed product. For the most part unless you have absurd RFI (and you would definitely know it) its just not going to effect devices all that much.... Unless you have underlying problems on top of that, like we do.
Sorry I have seen it enough times that I wont sit here and bury my head in the sand anymore. I believe I can see with some clarity on this as I have the problem fairly severe. Maybe for many it is not that bad. But it sure makes it abundantly clear what is what when I can take my PC to a friends and it preforms flawlessly. No need to do ten thousand arbitrary reg-edit tweaks or messing with the electrical setup. It just works.
