It shouldn't be risky, but backup is always advised. I heard unchecking it helped with ntoskrnl.exe dpc latency spikes, but it didn't for me. And mouse felt like shit. I have best experience with having Intel nic with enabled MSI.
Some mysterious effects on gameplay
Re: Some mysterious effects on gameplay
My comprehensive TWEAKGUIDE: https://www.tenforums.com/gaming/117377 ... ost1454596
Anandtech DPC latency tests: https://www.anandtech.com/show/13468/th ... i-review/5
Update 2 -
After this, the speedstep is resolved, it looks like a defect in the BIOS - with all defaults and speedstep enabled the CPU is configured with 1-core ratio 42 and 2-4 core ratio 40; with speedstep disabled it's all core 40, and the ring ratio is 41. Now I run an all-core 45 static overclock and it's better. There is one interesting thing - although setting ring ratio to core ratio gives the lowest latency, setting ring ratio to (core ratio - 1) gives a special comfortable feeling. Are there any insights on this?
Now overclocking RAM to 3200 becomes stable, and memory latency dropped to 35ns. Dual channel is still bad. FCLK 1GHz is still bad.
Edit: History repeats itself - after playing with 3200 for several days I developed headache, switched back to 2400, and the gameplay feels significantly better.
Thanks! Although I knew it was unstable I haven't fixed it previously, you encouraged me to give another try, and ... I tried a lot of random things, and when I turned on ThrottleStop, the gameplay suddenly became so good. This is a 6700K at stock with HT disabled with good PSU and cooler, I can't believe it can run into power limits. Although ThrottleStop doesn't show any throttling, disabling power limits made a big change. Previously disabling speedstep or overclocking only make things worse and I should have noticed this.
