Hi....
My negative experience with the new monitor, is it defect or just the input delay?
My new monitor that I experience that slow motion on is..
ASUS TUF Gaming VG279QM 27” HDR Monitor, 1080P Full HD (1920 x 1080), Fast IPS, 280Hz, G-SYNC Compatible, ELMB Sync,
My other monitor I use to main playing Fortnite on was a 2K monitor with
NO slow motion happening while playing..
Acer 27" Predator XB271HUA, 165Hz, G-Sync, ULMB Sync,
I have formatted my PC with test before and after, same motion effect and delay,
Tried with only one monitor ON, still happening.
Tried different DISPLAY Ports.. even tried to mess around in the OSD turning ON & OFF ELMB or G-Sync, still the same issue,
Lowered the HZ to 240hz and less, still same issue. OVERDRIVE on 60 at the moment, tried them all there to.
The other monitor is not having this issue, SLOW free experience on that one.
The slow motion experience happens often when I start building or when I turn around with my character in game,
Turned off v-sync and playing on performance mode, please would appreciate some help,
Cant figure it out whats causing this issue, is this even normal for gaming monitor?
Please if you see this and have something, could be anything, then just write,
would appreciate any ideas to be honest!
Thanks for all the effort!
Fortnite & SLOW motion gameplay!
Re: Fortnite & SLOW motion gameplay!
Try to reinstall Graphic Driver with an DDU app.
Did you use 2 monitors at the same time? More info, and PC specs, if possible!
try it plug AC power plugs psu monitor another side
Yeah i did that with old driver and new driver, same thing on them both, im starting to think its the GPU or the CPU that can't handle the monitor or the FPS output to the monitor, don't know really just speculating here.
Yeah im using 2 monitors at the same time, is that even good to do? The other one is the 2k monitor, the main one atm is the 280hz.
My PC Specs,
HyperX 32gb 3200mhz - ram
500 gb m.2 - harddrive
1080 Super 8gb - gpu
i7 8700k intel - cpu
The game is really good at the start, mouse has no force or delay to aim or anything, then after some minutes it starts.
The tempature and everything looks okay i guess on HWMonitor.
CPU on 80 degrees after some time while gaming.. and back to 70 can happen that it stands at 90 for a short time.
GPU stands at 60-70 degree while playing,
Im really confused and really concerned about what it could be, sad story short.
Thanks for trying to help me, appreciate that.
Nope. Remove AC plug from the socket your power strip and change the side.Hiddenbars wrote: ↑23 Feb 2021, 23:04How do you mean exactly ? Should I remove the AC plug from the power supply cable and change the side?
I tried to put the monitor on another display-port on the GPU,
Yeah I have tried to change the side and even directly to a wall, no results.TN_fun wrote: ↑24 Feb 2021, 05:53Nope. Remove AC plug from the socket your power strip and change the side.Hiddenbars wrote: ↑23 Feb 2021, 23:04How do you mean exactly ? Should I remove the AC plug from the power supply cable and change the side?
Don't know if this has to do with anything but when i start the pc next day, this happens every time,
the screen goes black for like 2-3 sek after like 5-10 min pc on, and then it stops, never happens again.
Could it be something with my pc or monitor? What do you think?
maybe your monitor drops the frequency to 144Hz after a black screen, as do vg259qm(bug)?
No more ideas. Maybe Is the ips panel too slow for you?
- BTRY B 529th FA BN
It could be dropping the display Hz. I use to have one and more often than not it would boot up in 144Hz mode instead of 280Hz. Apparently there is a work around involving a tool called CRU but monitors shouldn't have this problem for the money they ask.
I have not tried CRU, maybe that can fix it im not sure, have to make a try, but is it safe? Still have my refund time on that 280hz monitor, hope it wont break.BTRY B 529th FA BN wrote: ↑24 Feb 2021, 14:47It could be dropping the display Hz. I use to have one and more often than not it would boot up in 144Hz mode instead of 280Hz. Apparently there is a work around involving a tool called CRU but monitors shouldn't have this problem for the money they ask.
I updated my bios, turned off a function, something to do with the timer insids the pci, it helped a little bit, but the slow is less now, but still there, the function had something to do with timer resolution, something under system devices insids device manager, just wrote it here if that maybe helps other people, but gonna try the CRU, keeping you guys updated, and thanks
