ok
Input Lag and Mouse Movement Tweaks for Gaming v3 2020 Edition
Re: Input Lag and Mouse Movement Tweaks for Gaming v3 2020 Edition
- BTRY B 529th FA BN
Do you guys disable FSO on Steam also?
I mean steam doesn't run in Fullscreen, maybe if you use 3D desktop? It can't hurt to disable it right?
My comprehensive TWEAKGUIDE: https://www.tenforums.com/gaming/117377 ... ost1454596
Anandtech DPC latency tests: https://www.anandtech.com/show/13468/th ... i-review/5
I imagine Steam Friends chat would trigger FSO DWM, same with EpicLauncher or any other launchers for their friends chat services or any overlay while in-game, or am I wrong to assume so and it's effect with DWM?
Some people said so in this thread. I don't use overlay, so I have no idea! But there should be no harm in disabling it. Some apps like Origin will complain, that you launched them in compability mode, if you change any settings there. But Origin also says: if you encounter any issues. So I think - that's just a general warning...BTRY B 529th FA BN wrote: ↑12 Mar 2021, 09:49I imagine Steam Friends chat would trigger FSO DWM, same with EpicLauncher or any other launchers for their friends chat services or any overlay while in-game, or am I wrong to assume so and it's effect with DWM?
EDIT: I was doing FrameTime analysis using this tool: https://www.nvidia.com/en-us/geforce/ne ... -download/
And in log it says Windowed mode. It has overlay, but once you start benchmark it is hidden. So it is confusing, why it says Windowed mode. I Am telling as someone said: overlays will cause game go to the Windowed mode, so it seems that it is so... This is with FSO disabled. Overlay are bad to use all time in general as they can cause fps drops etc. I don't use them, only when troubleshooting.
I just found a nice fix for floaty mouse on my current setup.
I'm using an XM1R with an AB350 Gaming 3.
The general rule about EHCI and XHCI hand-off is to disable EHCI hand-off and keep XHCI hand-off enabled.
I don't have EHCI hand-off in my bios so I assume it's disabled. I've been keeping XHCI hand-off enabled for basically over a year.
Yesterday I decided to disable XHCI hand-off which means that every USB 3.1 and 3.0 port is effectively turned into an USB 2.0 and I noticed that every floaty mouse issue I had was fixed, my mice and my keyboard both feel more responsive.
This is interesting because with XHCI hand-off enabled while using a USB 2.0 I still suffer from floaty mouse issues.
It is definitely not placebo, the difference is very clear on my setup. I'm wondering what could be the cause of this issue, from my understanding with XHCI hand-off disabled the USB functionalities are handled at a bios level so could the issue be caused by chipset/windows drivers? I'm very confused, I don't like losing USB 3.0 functionalities but I can't handle going back to XHCI hand-off enabled.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
@Axaro1 Use usbtreeview to get a closer look at your USB hubs and ports. I may not have comprehended it correctly but on my X570 Xtreme board the USB xHCI 3.0 hubs also include USB 2.0 ports.. so maybe the USB 2.0 ports were still behaving like USB 3.0 ports?
This seemed safe for my downloading of it:
https://usb-device-tree-viewer.en.lo4d.com/windows
with xHCI disabled:BTRY B 529th FA BN wrote: ↑15 Mar 2021, 07:45@Axaro1 Use usbtreeview to get a closer look at your USB hubs and ports. I may not have comprehended it correctly but on my X570 Xtreme board the USB xHCI 3.0 hubs also include USB 2.0 ports.. so maybe the USB 2.0 ports were still behaving like USB 3.0 ports?
My mouse (XM1R) is connected to a USB 3.0 port
It does say:
Code: Select all
USB version : 2.00 -> [b]wrong, device is Full-Speed only[/b]
Port maximum Speed : High-Speed (Companion Port 1-7 supports SuperSpeed)
My keyboard is connected to a USB 3.1 port
And finally I connected my USB microphone to the USB 2.0 DAC-UP port
*= currently owned
*= currently owned
Strange I had already disabled Xhci hand-off in BIOS and it doesn't turn USB 3 ports into USB 2. Isn't this for older systems, which have problem with utilizing USB3 ports?
I can't unfortunately disable USB 3 anyways, even if I could, I need it for VR!
I have another problem: even when no USB 3 devices are connected. I have only USB Root Hub (USB 3.0) installed. But when I disable every single USB3 port in BIOS, I have only USB Root Hub installed and mouse movement is better! Even I have still only Xhci drivers and no Ehci, since new motherboards supposedly have only Xhci drivers!!!
Also since we are talking about mice, I was reading yesterday R0ach posts and found this gem: https://www.overclock.net/threads/how-t ... t-28522852
Didn't try it yet, since I have some problems with device manager. Can't hide disconnected devices! So I don't want to do it, in case: order of devices would change, after disconnecting a mouse! But this issue cause input lag and clown mousefeel supposedly for so many peoples...
axaro1 wrote: ↑15 Mar 2021, 08:27with xHCI disabled:BTRY B 529th FA BN wrote: ↑15 Mar 2021, 07:45@Axaro1 Use usbtreeview to get a closer look at your USB hubs and ports. I may not have comprehended it correctly but on my X570 Xtreme board the USB xHCI 3.0 hubs also include USB 2.0 ports.. so maybe the USB 2.0 ports were still behaving like USB 3.0 ports?
It does say:According to Endgame Gear my XM1R is supported by USB 2.0 Type ACode: Select all
USB version : 2.00 -> [b]wrong, device is Full-Speed only[/b] Port maximum Speed : High-Speed (Companion Port 1-7 supports SuperSpeed)
On port 8 it's showing my cpu water cooler connected. Is it safe to disable it or am I screwed. Also, on port 1 & 17 it's showing USB (Realtek Semiconductor Corp.) which I have no idea what that is. Can I disable these safely?
- Port8.png (117.51 KiB) Viewed 6362 times
