Hey,
unfortunately as some of you may know the LG GL850-B has suboptimal HDMI bandwith. Its not possible to input a signal of 1440p@120hz with VRR enabled over the HDMI port (which would be the most optimal setting).
So I have a question what setting I should use on Xbox Series. Would you rather play with...
1. 1080p@120hz with VRR enabled. Lowest Input Lag BUT horrible upscaled picture (in my opinion)
2. 1440p@120hz without VRR enabled. its more responsive than at 60hz (atleast without VRR enabled)
3. 1440p@60hz with VRR enabled.
I wish there would be a fourth option, but unfortunately the 120hz seems not to stick with 720p (better upscaling to 1440p than from 1080p). Oh well.
So which is the best? Is the 3rd option atleast as responsive as the 2nd or better overall? Or would you rather take worse picturequality?
LG 27GL850-B - best setting on Xbox Series?
Return to “Input Lag / Display Lag / Network Lag”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
