For people with input lag/desync ONLY in csgo (mainly faceit ac)
Straszy
Post by Straszy » 20 Apr 2021, 16:50
Please do this, tell me if you feel the difference. For me it's a lot better, much less prefired and game is smoother.
I want more people to test it to see if it's placebo.
yonaxsangi
Re: For people with input lag/desync ONLY in csgo (mainly faceit ac)
Post by yonaxsangi » 20 Apr 2021, 17:10
Straszy wrote:
20 Apr 2021, 16:50
but its on backround services in default bro? maybe i need to choose programs?
Straszy
Post by Straszy » 20 Apr 2021, 23:34
Programs is default...
iceboy
Post by iceboy » 21 Apr 2021, 13:46
This controls the Win32PrioritySeparation registry field mentioned by multiple optimization guides, and basically controls the quantum size used by the windows kernel scheduler. Generally a large quantum size can minimize context switches and gives best performance while a small quantum size can help prevent priority inversions. In my opinion, if you have priority inversion then you already have a problem and it's best to solve it rather than relying on the scheduler, so the largest quantum size should always be used.
player1
Post by player1 » 22 Apr 2021, 03:21
Straszy wrote:
20 Apr 2021, 16:50
Can u say something more about your PC specs and ingame settings (resolution, details)?
What CPU are u using? What version of Windows, untouched or modified?
No sense that setting is causing lag, maybe Faceit Anticheat is responsible being background process?
JDoe
Post by JDoe » 22 Apr 2021, 12:52
Tried your fix, no difference.
Mugabi
Post by Mugabi » 27 Apr 2021, 05:53
How can i do this? Any steps?
JDoe
Post by JDoe » 28 Apr 2021, 01:16
I think the better way to do it is to set high priority for Faceit AC in process manager. I retested it couple of times and setting processor scheduling to background services definitely reduces my in-game performance while setting high priority for Facet AC only at worst doing nothing.
player1
Post by player1 » 28 Apr 2021, 02:02
Mugabi wrote:
27 Apr 2021, 05:53
Right click on This PC -> Properties -> Advanced System Settings -> Advanced (3rd tab) -> Settings (in Performance part) -> Advanced (2nd tab).
ELK
Post by ELK » 14 May 2021, 03:48
JDoe wrote:
28 Apr 2021, 01:16
It has been seen that setting a game's process to high priority can hinder mouse driver performance. Based on this observation, (not sure what game(s)) you should never raise a game's process priority
