Disabling power save mode bios
morelczi
Post by morelczi » 05 May 2021, 19:17
Hello guys,
Can anyone explain me what options should i disable in bios to completly disable cpu power saving mode? Heard that could make a less input lag/more fps in csgo.
Motherboard: gigabyte z390 UD
Thanks!
yonaxsangi
Re: Disabling power save mode bios
Post by yonaxsangi » 07 May 2021, 10:49
morelczi wrote:
05 May 2021, 19:17
Hello guys,
Thanks!
disable all c- states , prefetch and all the features exept turbo boost
f1ndus
Post by f1ndus » 07 May 2021, 10:54
i give you 1 advice after my many years fixing this problem. Everything what you do in windows or bios is just placebo, if something change and helped its just question for minutes - hours and after then everything is bad again.
you should fix your electricity problem, no one knows whats the source , if its EMF or electricity in your house
dervu
Post by dervu » 07 May 2021, 11:18
Why assume everyone who talks about input lag has this problem?
Ryzen 7950X3D / MSI GeForce RTX 4090 Gaming X Trio / ASUS TUF GAMING X670E-PLUS / 2x16GB DDR5@6000 G.Skill Trident Z5 RGB / ASUS ROG SWIFT PG279QM / Logitech G PRO X SUPERLIGHT / SkyPAD Glass 3.0 / Wooting 60HE / DT 700 PRO X || EMI Input lag issue survivor
MatrixQW
Post by MatrixQW » 07 May 2021, 12:49
You don't need to disable it in BIOS, just use Windows power settings "High Performance".
This way you can still make use of power savings if you want to by changing this setting.
You can do the same for Nvidia, create a profile for a game with "Maximum performance" and leave the global setting to "Optimal Power".
MatrixQW
Post by MatrixQW » 07 May 2021, 13:04
yonaxsangi wrote:
07 May 2021, 10:49
On my cpu, turbo boost only works with c-states enabled.
