Mouse is having input lag, but when i disconnect it and plug it in it's gone for 10 seconds and comes back.
leka164
Post by leka164 » 05 Jun 2021, 20:31
I suspect this might be an electricity issue, mouse feels heavy and varies on the day. Feels better on the night rather than the day.
I'm also living close to a laundry room.
My current PSU is from a factory built computer from HP, it's 310 watt. Could an upgrade be a possible fix for this?
delve
Re: Mouse is having input lag, but when i disconnect it and plug it in it's gone for 10 seconds and comes back.
Post by delve » 07 Jun 2021, 02:56
which gpu + cpu are you running with the power supply?
f1ndus
Post by f1ndus » 07 Jun 2021, 03:13
just unplug your CPU fan from CPU fan and plug somwhere else, easy fix xD
slaver01
Post by slaver01 » 07 Jun 2021, 03:24
f1ndus wrote:
07 Jun 2021, 03:13
f1ndus
Post by f1ndus » 07 Jun 2021, 03:36
slaver01 wrote:
07 Jun 2021, 03:24
f1ndus wrote:
07 Jun 2021, 03:13
few guys fixed it with switch CPU fan from CPU fan slot to other slot like cpu opt or sys fan, but for me not working
