Mouse is having input lag, but when i disconnect it and plug it in it's gone for 10 seconds and comes back.
leka164
Post by leka164 » 05 Jun 2021, 20:31
I suspect this might be an electricity issue, mouse feels heavy and varies on the day. Feels better on the night rather than the day.
I'm also living close to a laundry room.
My current PSU is from a factory built computer from HP, it's 310 watt. Could an upgrade be a possible fix for this?
delve
Re: Mouse is having input lag, but when i disconnect it and plug it in it's gone for 10 seconds and comes back.
Post by delve » 07 Jun 2021, 02:56
which gpu + cpu are you running with the power supply?
f1ndus
Post by f1ndus » 07 Jun 2021, 03:13
just unplug your CPU fan from CPU fan and plug somwhere else, easy fix xD
slaver01
Post by slaver01 » 07 Jun 2021, 03:24
f1ndus wrote:
07 Jun 2021, 03:13
f1ndus
Post by f1ndus » 07 Jun 2021, 03:36
slaver01 wrote:
07 Jun 2021, 03:24
f1ndus wrote:
07 Jun 2021, 03:13
few guys fixed it with switch CPU fan from CPU fan slot to other slot like cpu opt or sys fan, but for me not working
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 08 Jun 2021, 10:15
It might be DPC calls from other devices e.g. NIC, causing the stutter. With AMD you can view what Core your mouse is tied to by running Ryzen Master. You can also view DPC calls with xperf which would help alot
