Tip windows install responsive trick
pox02
Post by pox02 » 15 Jul 2021, 01:51
when u install windows drivers games everything feels snappy right but after time its gets worse download deep freeze or shadow defender when everything snappy problem solved after reset windows become snappy again so u dont have reinstall windows again and again :D
wadge
Re: Tip windows install responsive trick
Post by wadge » 15 Jul 2021, 06:23
Can you give some more details on how to proceed exactly ?
This could be interesting
Thank you
Unreazz
Post by Unreazz » 15 Jul 2021, 09:31
Dude can you write this post in a prooper english again ? after 5 times of reading i didnt understand anything. Windows became snapier but after time its get worse again and then you have to reset ? to became snaper again what ?! or a new clean install ?
milojr21
Post by milojr21 » 15 Jul 2021, 09:38
ive been using macrium reflect its free/portable and works well. i have 3 ssd drives hooked up, 1 for storage(1tb), 1 for main os(120gb), 1 that has the fresh install with windows and everything feels great(120gb) this one is disabled and only enabled when i need to clone. when my main os drive feels like crap i just simply enable my fresh install ssd and clone it to my os drive. takes like 4 minutes and everything feels good again.
Unreazz
Post by Unreazz » 15 Jul 2021, 11:26
milojr21 wrote:
15 Jul 2021, 09:38
You copying the whole windows files from youre fresh installed OS and overwrite everything on youre main os ?
milojr21
Post by milojr21 » 15 Jul 2021, 12:51
Unreazz wrote:
15 Jul 2021, 11:26
milojr21 wrote:
15 Jul 2021, 09:38
Exactly. It saves so much time, especially if you did your preferred tweaks you don't have to redo everything it will clone in less than 4 minutes, rinse and repeat when the os starts to feel muddy.
ChadTerry
Post by ChadTerry » 13 Feb 2023, 09:31
Thanks for sharing your tip on how to keep your Windows install feeling snappy. I've heard of Deep Freeze and Shadow Defender but never considered using them to keep my Windows setup running smoothly. That's a great idea!
mago
Post by mago » 13 Feb 2023, 16:22
need to freeze just the OS ?
Ⓢк𝕀lŁ เ𝓢 ᵗⒺм𝕡σr𝐀𝐑Ⓨ, lά𝔾 I𝐬 F𝔬ʳ𝔢𝓿ᗴ𝔯
Zodasaur
Post by Zodasaur » 14 Feb 2023, 04:40
milojr21 wrote:
15 Jul 2021, 12:51
Unreazz wrote:
15 Jul 2021, 11:26
milojr21 wrote:
15 Jul 2021, 09:38
It's not 4 minutes. It takes over 15 minutes to clone.
mago
Post by mago » 14 Feb 2023, 07:28
mb better to do with vhd differencing disk
