Gaming Router to eliminate bufferbloat
Simon95
Post by Simon95 » 23 Jul 2021, 00:22
I search a router that reduce the bufferbloat. Can someone suggest a good router? I have 30MBIT Internet VDSL.
milojr21
Re: Gaming Router to eliminate bufferbloat
Post by milojr21 » 23 Jul 2021, 03:52
I purchased a NETGEAR XR300 for this reason. Seems OK, no issues with it. Bufferbloat test are A+ now, but honestly I don't notice a difference while gaming.
Simon95
Post by Simon95 » 23 Jul 2021, 06:45
In my home are a 4 persons which use the internet. When one person watches Netflix I will have pi g and packet loss issues. With queue management this should not be a problem.
slaver01
Post by slaver01 » 26 Jul 2021, 10:03
Option 1: EdgeRouter X - 50,00 $
https://youtu.be/o-g2P3R84dw?t=589
Option 2: I solved it like this with fibre 1gb
From CMD run this command:
netsh int tcp set global autotuninglevel=disabled
(restart the pc)
FOR RESTORE: netsh int tcp set global autotuninglevel=normal
Simon95
Post by Simon95 » 27 Jul 2021, 14:42
Do i need to use my old router as modem to use the edge router or are there gaming router with an modem vor VDSL2.
axaro1
Post by axaro1 » 27 Jul 2021, 15:02
I can vouch for Asuswrt-Merlin compatible Asus routers.
Fq_codel is great to reduce bufferbloat.
https://github.com/RMerl/asuswrt-merlin ... isciplines
https://www.asuswrt-merlin.net/
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
readtext
Post by readtext » 29 Jul 2021, 13:21
try to get one with linux
edgerouter x is cheap and good. You can use QoS cake, which is the best right now.
Simon95
Post by Simon95 » 30 Jul 2021, 16:34
I bought the dsl Asus ax82u.
victor910
Post by victor910 » 31 Jul 2021, 00:30
Ignore these stupid websites with tests.
If you want a real test, start the download torrent with 200 seeds with unlimited download speed.
Start playing the online game while torrent download at maximum speed in your channel.
If you game ping jump or going up, your router is bad. End of the story, you will be definitely under bufferbloat.
I change a million devices, and the only cisco passes this test properly, of course with the right configuration ;).
Crazyness
Post by Crazyness » 31 Jul 2021, 07:15
slaver01 wrote:
26 Jul 2021, 10:03
(restart the pc)
using this command in CMD .. before triple A..after triple A+..the only thing i noticed after implementing this command,is that my dl speed on that particular site for testing was reduced from 850-950dl to 150-170dl..even thou my actual speed didnt changed..its as usual 900-950.. so this command works..good shit
