XL2411K vsync tester
Hi, when I play CSGO I have weird stutters especially when I see the enemy. I have trouble in finding the cause of it. I reinstalled my drivers with DDU and still nothing. Peaks during vsync test are present more or less in the same place on the graph (dunno if it's anyhow related with csgo). With XL2546 I was able to make perfect results but now I believe my monitor is faulty. Any other ideas how to identify the cause of the problem?
- vsynctest.png (1.18 MiB) Viewed 2224 times
Re: XL2411K vsync tester
Hi. Why did you change 240 and 144 Hz your monitor broke down?
Ok now I have Acer Predator XB253QGX and it's the same. I am not even able to do the ufo test, because it stutters on every web browser. Any ideas how to fix it?
- vsynctest1.png (1.06 MiB) Viewed 2043 times
Fixed with disabling all RGB features. Thanks to Chief and his advise in another thread.
