Hello Guys,
I have a tricky question.
I read somewhere when buying a 144HZ monitor, you will get less input lag then on 60HZ monitors thanks to faster scanout times.
Now, I cant always achieve 144HZ in some games and I dont like to much tearing so I cap the FPS to 1/2 of the refresh rate. So 72FPS on 144HZ, or 60FPS of 120HZ.
Im wondering if you get the same input lag on 144HZ when capping your frames to 72FPS? I know the frame times will be much longer, but will I get the same scan out input lag of the monitor on 72FPS?
Display Lag at 72FPS and 144HZ?
Return to “Input Lag / Display Lag / Network Lag”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
