Wierd lag prob due to 2.4 wifi not power here how test
Posted: 16 Sep 2021, 17:11
Seriously test out yourself use wifi analiser app on your phone and see what 2.4 closest to you channel using. Then put your 2.4 wifi on same channel even if you dont use have on put on and set channel. Mine is channel 1 best. This isn't cut dry fix you're pretty much fighting air i found one neighbore wifi that causing the lag. i also stuck unused wifi router same deal stuck 2.4 on same channel and stuck it on my computer acting as a barrier i also got Deauther Watch off amazon and i can hit this access point and computer fine. Even if you dont use wifi turn it on and use it and try figure it out and act as barrier it not easy not matter what i could never get %100 untill i found out phone charging cables make sure all are unplugged from outlet and disconnect from your device. IDK why they act way they do but they are terrble act as antenna interfience. Also dont leave facebook running on ipad or android close it becasue runs in background my mom did i found out had to turn off all background garbage from running faceboot contantly monitoring it was somehow contributing even though she on 5ghz it all air frequecies IDK how they work but im starting find out wifi problem. Also found tucking mouse and monitor cable under tower helps.
https://play.google.com/store/apps/deta ... nalyzerpro
Deauther Watch *FYI this isnt a jammer*
https://www.amazon.com/s?k=Deauther+Wat ... nb_sb_noss
You can also try somthing like this for your cables to stop it
https://www.amazon.com/Tinned-Copper-Br ... 363&sr=8-3
I live apartment been dealing with over year almost got kicked out becasue they wouldnt fix what i thought was ground loop or dirty power. We and have so many 2.4 wifi it unreal comcast making shit so bad they even pushing mesh network and got these people with ridiculous wifi on small arpartment.
Ive had couple neighbors turn off 2.4 and everything great justr doing that they older people who dont even use internegt comcast just talked them into it They still have 5ghz. Also got into office router and set up schedule for wifi to turn off wifi they are not working that was another one causing bad lag old ass router
edit
Another thing did was got my mom new LG TV she doesn't use smart functions and you cant turn off wifi even if you hook up wired so took back cover off disconnected wifi. That seem to be acting as antenna for further ways signals 2.4 wifi sucks so back shouldn't even be legal seriously with high end sensitive equipment this becoming huge issue.
And sorry if all over place bad ADD
edit
