This is a known issue with CSGO. Some ppl fixed it by using external soundcard and disabling onboard audio, some just by tweaking audio enhancements. Ive seen a post from a guy who was a pro until his game went to shit. He has been switching places, changing ISPs and PCs, spent thousands of dollars and the only thing that worked for him was a bluetooth speaker - game was smooth and sharp as it should be with no hitreg issues, but he coudnt repeat result in any way, but using same BT speaker.a_c_r_e_a_l wrote: ↑06 Oct 2021, 20:29While playing on aim map with bots and changing some settings in config, just out of curiosity I set volume to 0 in the console. Then from snd_mixahead 0.01 to 0.025 because it's giving different mouse feel (no idea why but I trust me or not, I am not alone) and CS:GO became smooth like a hell. No stutters while shooting and spraying. Then joined DM because I couldn't believe in the change and it was still there.
I knew that my stuttery spray was somehow related to the in-game sound but I can't really explain why is this happening. I've had external Creative sound card, but it didn't change anything. Perhaps somebody can check it by yourself and confirm that your experience is the same?
I think that CSGO is pure magic at this point, my game just randomly becomes shit, cant get above 2400 elo just because I havent had even 2 days in a row with a decent gameplay experience, mostly its 1 in 3-6 games works fine. Seems like snd_mixahead 0.05 works the best for me, but even that doesnt help when I have "those days")
And I still dont get, how sound can make my spary randomly go all over the map and turn enemies into a nascar)
Do you know how can I put the sound card on the PCU lanes and disable 3D sound effects? Not that I think it will magically fix everything, but at this point Im not looking for fixes, just trying to mitigate the issue in any way possible)BTRY B 529th FA BN wrote: ↑07 Oct 2021, 11:29Wonder if putting the sound card on the CPU lanes and disabling 3D sound effects etc in the sound card properties will reduce the issue. Possibly using low 16bit CD quality too...
