Method to Cap GPU Usage?
Re: Method to Cap GPU Usage?
Post by RealNC » 15 Oct 2021, 09:54
kyube wrote:
15 Oct 2021, 08:06
G-SYNC and V-SYNC both on gives me a very weird mouse movement delay (on a XG2401 and 1050ti, so Freesync to NV gpu's). It's very apparent when switching back and forth between vsync off gsync off vs vsync on and gsync on (even gsync on feels like dragging mouse thro mud)
Could it be possible that this is caused due to high GPU usage?
A friend of mine with the x25f also reported similar findings, could this be monitor related? Or perhaps the fact we're using NV gpu's on freesync monitors and the implementation is flawed on our monitors?
At the same FPS? For example, if you use a 130FPS cap for both cases (130 to preempt nvidia's automatic cap, just in case,) then you get a big difference in mouse feel?
