same on 7
Bad mousetester graph when videocard is on
Re: Bad mousetester graph when videocard is on
- win7.png (111.86 KiB) Viewed 3184 times
I don't know what to use to play (fortnite).
w10 i have more fps than w7. Should I look more at the graph or at the fps?
W10 21h1: driver 471.96
- Max 719 fps
- 1% 91 fps
- 0.1% 39 fps
W7 sp1: driver 471.96
- Max 625 fps
- 1% 89 fps
- 0.1% 37.5 fps
- Max 719 fps
- 1% 91 fps
- 0.1% 39 fps
- Max 625 fps
- 1% 89 fps
- 0.1% 37.5 fps
if fortnite use dx11, w10 better.
try 8.1
i try to CLRTC, maybe it work, see later
- win10.png (160.42 KiB) Viewed 3098 times
it is like factory reset bios with memory cache, but it not work in my case. same problem..
2 variants:
1) motherboard
2) emi, ha-ha
2 variants:
1) motherboard
2) emi, ha-ha
im use last revios, 0.5ms timer with 1 core affinity on my pci-e usb 2.0 card and useplatformtick no
