I go the new corsair 8k budget mouse and trying to figure out the best pooling rate for it here are the graphs for 2K, 4K, and 8k
do you guys think 8K is worth it, I don't think the mouse can even get up to 8K it is almost acting like it is a 4K pooling rate
SABRE RGB PRO CHAMPION SERIES WIRED 8K
- 8K.png (144.48 KiB) Viewed 982 times
- 4K.png (124.64 KiB) Viewed 982 times
- 2K.png (65.93 KiB) Viewed 982 times
Re: SABRE RGB PRO CHAMPION SERIES WIRED 8K
A lot of these problems are USB port related, try a different USB port, and/or use a PCIe USB card.
Also, 2000 Hz still gives you 90% of the benefit of 8000 Hz.
Only a few systems are actually 8KHz-ready.
I will try doing that and thanks for the reply appreciate it.
