Question: CRT + DVI-D to VGA Active Adapter
gukexpro
Post by gukexpro » 08 May 2022, 03:51
Hello guyz am new here
I have
CRT Monitor: Samsung Syncmaster 997MB 19 inch
GPU: GTX 1660
Adapter Converter: UGREEN MM108 https://www.newegg.com/p/284-00PH-009S4
Playing cs:go everything ok. i dont have any lag,but maybe have some lag and i cant feel it? is it normal am playing with this setup?
Re: Question: CRT + DVI-D to VGA Active Adapter
Post by Slender » 19 May 2022, 16:45
you need to buy gtx 980ti with vga to take full experience with crt zero lag.
Boop
Post by Boop » 20 May 2022, 13:11
https://youtu.be/puu-iyTsZtg?t=1188
Aperture Grille does a comparison of VGA to HDMI/DVI adapter, GPU Passthrough, and Native with a 980Ti. The latency results show the latency difference is almost non-existent with his adapters.
Boop
Post by Boop » 23 May 2022, 16:14
In case you didn't want to watch the video. (it's a very informative video)
VGA Adapter Latency
No Adapter, analog right out of the 980Ti
GPU Passthrough, 1070Ti doing the rendering and 980Ti outputting video to display
