Blur Busters Forums
Strobe Utility does not launch.
Postby Walde » 08 Aug 2018, 06:33
Hey!
Whenever I try to launch the Strobe Utility, I get the following error:
I cannot find any window or process linked to the Strobe Utility. Reinstalling the program didn't work, nor did rebooting. The Strobe Utility version is 2.0.9.
My monitor is BenQ Zowie XL2411P.
Walde
Re: Strobe Utility does not launch.
Postby Walde » 13 Aug 2018, 05:46
There's nothing on this?
Walde
Postby RealNC » 13 Aug 2018, 11:02
You can PM the author of the tool, I guess:
memberlist.php?mode=viewprofile&u=2
Postby Chief Blur Buster » 14 Aug 2018, 17:23
Usually mark[at]blurbusters.com is the best way. But I'll address it here.
1 -- Do you have Strobe Utility in your Windows startup? If so, is there a Strobe Utility window running in a hidden area (e.g. located off desktop) or in another Windows login? (Unlike for ToastyX or LightBoost utilities and others, it's not necessary to put Strobe Utility into the Startup)
2 -- Theoretically another app might unexpectedly mis-detect another window as Strobe Utility.
Try restarting in Safe Mode; does it run? If it works, then there may be a bug.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Postby Walde » 16 Aug 2018, 04:41
Chief Blur Buster wrote:Usually mark[at]blurbusters.com is the best way. But I'll address it here.
Thank you for your reply!
I double-checked if the app was somehow in my Windows startup, but no. So I tried launching it using the safe mode - And it launched just fine. :o
Walde
Return to BENQ/Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
Who is online
Users browsing this forum: No registered users and 5 guests
