Blur Busters Forums
Strobe Utility syncing with wrong monitor's refresh rate?
Postby GreenAlien » 11 Apr 2019, 06:30
I have two monitors. My Primary is a Zowie XL2730Z @ 144hz, and the secondary is a Samsung CF791 @ 100hz. When I run the Strobe Utility on the Zowie, it displays the correct refresh rate however it runs at 100fps rather than 144fps. Anyone know what I am doing wrong?
Thank you!
GreenAlien
Re: Strobe Utility syncing with wrong monitor's refresh rate
Postby Chief Blur Buster » 15 Apr 2019, 10:50
Strobe Utility sometimes has problems when your BenQ/Zowie monitor is not the primary.
This is the same problem as trying to run http://www.testufo.com simultaneously on two different-Hz multimonitor: It just doesn't work properly.
The frame rate usually synchronizes to the primary monitor, but sometimes it synchronizes to the wrong monitor.
Try minimizing all windows except Strobe Utility, then try again. (Make sure the Strobe Utility adjuster is on the same monitor being adjusted too -- e.g. no window on the 100Hz)
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Return to BENQ/Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
Who is online
Users browsing this forum: No registered users and 5 guests
