Hi,
I was wondering if there was an guide that show you the order to set up a monitor to get the best out of it for gaming.
Done the basic of getting it out and setting up the resolutions to 1080p 240hz, my next step was to set the colour up using x-rite i1 pro to setup a profile for working during the day, and one for gaming in the evening.
What is the next step, as there seems to be certain technologies benq have implemented to have an "advantage" over other, will I be reducing this effectiveness by setting up to be as colour accurate as I can.
Mainly playing warzone about the 170 - 200 mark, currently also trying to squeeze extra FPS out of my machine, and I started to read about 182hz, but the very first paragraph mentioned that it should maybe only be tackled by the more expierences in that department.
Also was watching some videos by a guy called fr33thy, and he was mentionioning reducing display resolution to get more FPS aswell.
Any help is much appreciated.
Thanks,
Jim
CPU: 3700x, GPU: Gigabyte 2080 Super OC, Ram: 4 X 8gb 3600mhz, Mobo: X570 Tomahawk
Is there a guide to setting up a new monitor for gaming xl2546s
Return to “BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
