Blur Buster Strobe Utility and Valve Anti Cheat
Hi, i'm just asking to be 100% sure. Is it fully safe to play CS:GO while using this program? Does it inject itself into games? I don't want to get VAC banned.
Re: Blur Buster Strobe Utility and Valve Anti Cheat
The strobe utility simply communicates via DDC commands to the monitor. It has absolutely NOTHING to do with game exe's, period.Anonymous871231 wrote: ↑18 Mar 2020, 19:24Hi, i'm just asking to be 100% sure. Is it fully safe to play CS:GO while using this program? Does it inject itself into games? I don't want to get VAC banned.
The settings the strobe utility can sets are the same ones that are in the Service Menu (Strobe Duty/Intensity, and Strobe Phase/Area, and on older blur reduction (Mstar) models, Single Strobe (85hz and below).
Falkentyne is right.
Strobe Utility is simply a PC program that makes it easier to do what you can do via the monitor's hard-to-reach Service Menu, and also makes it easier to calibrate by running a built-in TestUFO motion test that aids in adjusting.
Some useful images on how to adjust for lower lag, or reduced crosstalk.
viewtopic.php?f=13&t=6430
You can just quit the software afterwards. There is no problem with anticheat.
Strobe Utility is not a cheat -- and it has no known anticheat ban / VAC ban of any kind.Anonymous988125 wrote: ↑10 Aug 2022, 06:40You won't have any problems with Anti Valve cheat if you use the Blur Buster Strobe Utility. You definitely don't have to worry
It's simply a monitor calibration utility, much like a color calibration utility, but of a different attribute (strobing instead of colors).
In many cases, these are mainly computer-side UIs that are far easier to use than the monitor's OSD menu or factory menu, for a specific task (because Strobe Utility has a built-in automatic TestUFO Strobe Crosstalk test).
