HELP factory reset Blur Busters Strobe Utility
Posted: 16 Oct 2023, 04:58
by Depo
Hello everyone,
I downloaded the Blur busters strobe utility tool for my XL2566K. I was silly enough not to make note oft the original calibration settings in the app. I'd like to basically revert my monitor back to its default values before using the app.
Note: I haven't used CRU or Toasty, just simply the Strobe Utility app.
Any help appreciated.
Re: HELP factory reset Blur Busters Strobe Utility
Posted: 18 Oct 2023, 11:02
by Depo
Bump.
Anyone??
Moderators?
Posted: 20 Oct 2023, 21:34
You have to factory reset via the monitor menus, to get the original strobe data.
Posted: 23 Oct 2023, 19:04
by Depo
Thanks Chief,
Just to confirm I don't need to reset anything using CRU either?
Not that I used CRU it's just I did a search and on here and the only info retrieved was someone saying you have to use the reset.exe from CRU as well?
Posted: 31 Oct 2023, 17:25
Depo wrote: ↑23 Oct 2023, 19:04
Thanks Chief,
If you want to remove the Large Vertical Totals (custom modes, custom refresh rates, etc), yes, you have to run ToastyX reset-all.exe too, in addition. This resets your Windows operating system to only use the original Plug-n-Play EDID's that the monitor is giving to your display.
