XL2420Z V1 firmware needed
I believe there is some sort of timing issue with the monitor in 144hz mode. Before I go into great detail does anyone have the V1 firmware? I didnt back it up before I flashed.
Re: XL2420Z V1 firmware needed
all 144hz settings if used or created in a custom resolution in CRU.exe must be used with LCD Reduced parameters, not Normal.
