Hello!
I decided to reprogram my monitor XL2720Z (v2), on firmware version 3.
But nothing happened. Acted according to instructions. The program MStar communicates with the monitor, and determines "Device Type Winb25Q16". Firmware is done without error. But still, no change is - v2. I need advice and help!
Many thanks...
XL2720Z V3
Re: XL2720Z V3
Problem solved.
Flashed the correct firmware (size 832kb).
