[HELP] No BENQ Z-Series monitors have been detected
tuutz
Post by tuutz » 14 Oct 2014, 15:35
I bought a XL2411Z today. It has Firmware version V002-20131209.
The strobe utility says to try reinstalling monitor driver. How do I even install any drivers? :D I checked the CD and there is nothing useful.
zefs
Re: [HELP] No BENQ Z-Series monitors have been detected
Post by zefs » 15 Oct 2014, 11:16
Do a "check for windows update" from the control panel of your PC and it will detect the driver, that's how it installed mine on Windows 8.1.
Falkentyne
Post by Falkentyne » 15 Oct 2014, 13:01
Turn the monitor off,
Enter the secondary service menu, by powering it on by holding down button #3 and #4 (at the same time) while pressing the power button, release the power button while holding down 3 and 4 still.
When the leds' flash, release all of the buttons.
Press button 5 to enter the secondary service menu (usually this enters the OSD)
Then press buttons 1 and 2 to scroll up/down to burnin and then press button 3 (or 4 ,whichever one is enter) to turn burnin off. Then press the bottom button (5) to exit.
Then power cycle it.
The regular service menu is holding down button #4 only ,while pressing power (that's where the input detection and strobe settings are, for that one, after you activate it, button 4 (not 5) enters it).
tuutz
Post by tuutz » 15 Oct 2014, 15:21
How are you numbering the buttons? Left to right: 1 2 3 4 5 Power, or right to left: 5 4 3 2 1 Power.
I cant get the secondary service menu to open, only the standard one.
EDIT: got windows to update the drivers and now the software works
Falkentyne
Post by Falkentyne » 15 Oct 2014, 16:20
Its 1 2 3 4 5 (up to down) ignoring the power button.
tuutz
Post by tuutz » 16 Oct 2014, 13:12
Falkentyne wrote:Its 1 2 3 4 5 (up to down) ignoring the power button.
But my buttons go from left to right, huh? (They are at the bottom of the screen)
