Blur Busters Forums
xl2411z to V4?[V4 download link & flash instructions]
Re: xl2411z to V4?[V4 download link & flash instructions]
Postby Falkentyne » 16 Mar 2016, 12:22
Turn the settings burn-in to off in the factory menu that appeared.
Falkentyne
Postby Edgarchik » 16 Mar 2016, 12:28
Falkentyne wrote:Turn the settings burn-in to off in the factory menu that appeared.
yeah thank you =) just fixed it right before you answer
but still have issue
Everytime I turn off->on monitor I have to re set my ama settings high->off->high because its fucking up each time I turn off monitor
is it intended or it can be fixed somehow?
Edgarchik
Postby Piaer » 29 May 2016, 17:33
Thanks for instructions.
Worked perfectly on my PC. MSI GTX 960 by DVI port. Was upgrading from V3.
Note: My bus was 0 - so don't forget to change it for the flashing process (tutorial omits that at the end)
Piaer
Postby Lagahan » 03 Apr 2017, 11:56
Looks like the svn is down at flashrom; "Can't connect to host 'flashrom.org': Network is unreachable"
Any ideas on how to proceed? I wan't to go from V3 to V4 on my 2411z using the guide.
EDIT: MY BAD: this post fixes the issue: viewtopic.php?f=13&t=779&start=440#p24110
EDIT 2: Done! Works perfectly, had to use i2c bus 0 on my old laptop that has a VGA port attached to a Quadro NVS 320 and had to use the different flashrom url but it was done quite quickly then in the end up. Crazy how you can do stuff like this with Linux, I don't use it often myself. Saves us from having to get a hardware solution!
Lagahan
Postby Chief Blur Buster » 03 Apr 2017, 22:00
Lagahan wrote:EDIT 2: Done! Works perfectly, had to use i2c bus 0 on my old laptop that has a VGA port attached to a Quadro NVS 320 and had to use the different flashrom url but it was done quite quickly then in the end up. Crazy how you can do stuff like this with Linux, I don't use it often myself. Saves us from having to get a hardware solution!
Glad it is working now!
Previous
Return to BENQ/Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
Who is online
Users browsing this forum: No registered users and 5 guests
