Benq Service+Factory Menus, VT info, AMA Low tweak
Re: Benq Service+Factory Menus, VT info, AMA Low tweak
Post by Chief Blur Buster » 09 Feb 2020, 00:55
nuninho1980 wrote:
05 Feb 2020, 12:49
I've XL2411P. Does factory menu have vertical total pixels (VTP) option? I would need to increase VTP to 1350 because I get bad crosstalk at 1920x1080@60Hz on Playstation 3 console.
Vertical Total is at the GPU output and cable level, not the firmware level.
Your PlayStation has to add a bigger blanking interval to the video cable, which it cannot do. The signal structure on the cable is what creates the vertical total.
Theoretically, a scan conversion feature within a panel could internally create a large VBI, however, the XL2411P panel does not do this.
You can reduce PlayStation crosstalk by pre-adjusting strobe phase with a computer BEFORE connecting to a Playstation, or using the factory menu instead to configure that. Test strobe phase at 0 and at 100.
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Ssiuk
Post by Ssiuk » 06 Apr 2020, 11:27
I have the perfect color setting with this menu bit when i clóset the menú the color setting Sony sabe. How i can save the setting if this menu?. Sorry 4 muy english and thanks.
I have a xl2546 ty.
Ssiuk
Post by Ssiuk » 06 Apr 2020, 11:31
I have a Xl2546 and when i close the Factory menu my color setting dont save. How i can save It?
Thanks and sorry 4 muy english.
p1um4
Post by p1um4 » 30 Apr 2020, 08:24
Hello!
Is it possible to use vt tweak with this two resolutions (640x480 100hz & 800x600 100hz), but WITH display scaling (NOT 1920x1080 gpu downscaling)? What values to use?
BenQ XL2411Z v4 / 180Hz OC / BR off
Falkentyne
Post by Falkentyne » 02 May 2020, 23:39
Ssiuk wrote:
06 Apr 2020, 11:31
The "color" setting on the factory menu?
On the older Z series "Mstar" scaler monitors, those settings *ONLY* worked with analog connections (e.g. VGA) and did absolutely nothing over digital connections.
Since I don't have any of the Realtek scaler newer monitors, I can't help you with that at all.
Falkentyne
Post by Falkentyne » 16 Oct 2020, 22:04
Unfortunately, for 120hz VT 1500 tweak while staying under 360 mhz pixel clock, the AMD stable settings cause frameskipping on Nvidia hardware. (Pixel clock >359.99 mhz causes 6 bit color from the monitor, which you don't want).
AMD settings (Vega 64, R9 290X, but 5700 XT is untested):
120hz, 1920x1080:
front porch: 48/3
Sync width: 32/5
HT: 2001
VT: 1499
pixel clock: 359.94 mhz
This works perfectly on AMD to not have frameskipping /microstutters and stays at 8 bit color depth.
On Nvidia RTX 3090, this is unusable. Pressing the S-switch after a monitor refresh change only has a 30% chance to remove the frameskipping. Unfortunately, VT 1500 is 360 mhz so we need another way, and VT 1499, 1498, 1497 are microstutter city, and VT 1496 is black screen (S-switch restores the screen but is still microstutters).
Use this:
Front porch: 24 pixels 3 lines.
Sync width: unchanged
Horizontal total: 1984 (because front porch was reduced, HT can now go below the floor of 2000 pixels)
Vertical Total: 1500
No stutters now on RTX 3090, reduced strobe crosstalk and I can't see any drawbacks so far.
If I get a XL2746S, I'll be able to update whether these tricks still work.
@Chief Blur Buster
I added this info here.
Jommy321
Post by Jommy321 » 12 Nov 2020, 06:06
How can i get in too factory menus in xl2546k
(Sorry for my Eng im from thailand) :D
