Any way to switch input modes quicker with xl2411z?
vizionblind
Post by vizionblind » 08 Nov 2015, 13:42
I have my xbox one hooked up to my xl2411z and I game on my PC as well. Is there a quicker way to switch from HDMI mode to DI mode instead of going through sub-menus by clicking on each button on the monitor?
also
when i go from gamer 2 mode from the xbox one back to my pc, I have to manually select gamer 3 mode. any fast way to do that too?
Falkentyne
Re: Any way to switch input modes quicker with xl2411z?
Post by Falkentyne » 08 Nov 2015, 13:52
No, you need the S switch for that. You can do that on the XL2420Z and XL2720Z. that's one reason why they are more expensive. (told you the S-switch is worth the extra $100 dollars! Not to mention the displayport connector...).
The XL2411Z is a budget entry level monitor. (like the XL2410T and XL2411T before it).
The most you can do is set one of the three customized buttons on the panel to "picture mode" and then change it that way. takes 3 or 4 presses that way instead of 1 with an s-switch button.
benq_user
Post by benq_user » 26 Dec 2022, 07:09
Solution here (two clicks on monitor buttons or keyboard shortcut to switch): https://www.reddit.com/r/Monitors/comme ... &context=3
