I just purchased a XL2411Z. It will arrive here in 48 hours.
But you think its the v4 firmware version ? Now in 2016... ?
Also, how to check to see what firmware its using ? Just go into service menu and look at the firmware version ? Should be like V004 ?
Xl2411Z v4 firmware ?!
Re: Xl2411Z v4 firmware ?!
Yes the service menu will show it.
sorry forum was 500 error or lagging or something
Can u tell me in advance how to enter the service menu ?
It's in the VT /service menu thread. Please search.
http://forums.blurbusters.com/viewtopic.php?f=13&t=2590
Some one told me now, that he bought this monitor two days ago from the same retail shop i bought myself. And the manufacture date was december 2015.
Its ok ? I mean its on v4 firmware ?
probably? I don't know but I would assume yes.
My XL2411Z just arrived.
The manufacture date is april 2016. Written on the box white sticker.
This is the service menu ?!
http://i.imgur.com/nTJCnGc.jpg
As far i can see there is no strobe duty, strobe phase and single strobe options.
Its not the common benq service menu. Can u explain ?
If i want to control the strobe i need blur busters utility ?
That's not the service menu.
That's the factory menu (aka "Burn in" menu).
When a monitor is firmware flashed (e.g. with the Mstar ISP device, or with Linux Ubuntu), the burn in menu is usually enabled after a flash. That menu can be disabled by turning Burn-in to Off, then power cycling the monitor. The factory menu is enabled by holding 2 buttons while powering on the monitor (I don't remember which, as its different on the 2411Z than the ones with touch buttons), while the service menu is enabled by holding 1 button when powering on. Note that you can't enable the service or factory menu right after an "AC" power off (unplug); the monitor has to be powered on with AC first, then powered off with the power button, then you can enable the menu.
The 11Z code is in my VT thread. On the XL2720Z and XL2420Z its button #4 while powering on.
The service menu is the one with the strobe settings and the stuff like internet café (which you always want disabled) and HPD stuff.
Yeah.
Ok, here is the service menu.
http://i.imgur.com/NGQn0Ic.jpg
I assume that strobe duty and phase are the same as ones from the blur buster's utility ?
What does single strobe ?
And whats that tweak with the AMA setting ? I've read something about it but i didn't understood.
