Hello and thank you for the free software.i have one question.
Im playing on ps4 with the above monitor(xl2411z) game :cod ww2 60 hz
I have enable single strobe and im using persistence 10 and crosstalk 95.
Is it necessary to have blur reduction enabled from my monitor settings in order the settings i made to function properly?
Thanks in advance!!
xl2411z and ps4 60hz
Re: xl2411z and ps4 60hz
A reply would be greatly appreciated, I'm looking all over the internet for a reply, thanks again.
The strobe utility adjusts motion blur reduction parameters. If you don't use motion blur reduction, then you don't need the utility.
Hi and thank you, let's say, from the service menu I turn on single strobe on and I also change the other 2 parameters. IF I don't turn on blur reduction the changes I made will not apply?
If you don't turn on blur reduction mode, blur reduction settings have nothing to apply to.Lospsi wrote:Hi and thank you, let's say, from the service menu I turn on single strobe on and I also change the other 2 parameters. IF I don't turn on blur reduction the changes I made will not apply?
Οκ ,after lots of reading and your help I understood how it works.
Strobe Utility only affects Blur Reduction.
So, yes, you need Blur Reduction enabled to utilize the saved Strobe Utility settings.
Remember. When adjusting Xbox, you need to adjust 1080p 60Hz via PC first, before switching to the Xbox.
