I am trying to set my XL2411Z up for the best settings on CSGO. I am using 120hz DVI-D dual link. Can anyone help me run this program please?
mst 8556T
v004-20141205 (firmware version)
strobe duty 020
strobe phase 100
single strobe off
are my settings right now.
Can't use Strobe Utility on XL2411Z (New unseen error)
Re: Can't use Strobe Utility on XL2411Z (New unseen error)
- Try a different cable (or different port on monitor)
- Try a different video port on your card
- If you have a 2nd computer at home, test it too
- Try running the software as Administrator Mode (this is no longer needed for Strobe Utility 2.0.9 but do this test)
Barring that -- the Service Menu is also an alternative (harder) way of adjusting the same settings that Strobe Utility is (much more easily) able to do.
