About the BenQ XL2540 and the BenQ XL2546
LummyTum
Post by LummyTum » 18 Nov 2018, 08:20
So I was gonna get a BenQ XL2540 but it's out of stock in my region, the BenQ XL2546 isn't out of stock in my region and they cost the same.
I wanted to know...
1. Is dyac the only difference between the BenQ XL2540 and the XL2546?
2. If I buy the BenQ XL2546, can I turn the dyac off?
3. Should I use dyac?
ixenovia
Re: About the BenQ XL2540 and the BenQ XL2546
Post by ixenovia » 19 Nov 2018, 13:32
Hi man I ll try to respond at your question
I am not sure about this, but dyac is just a different name of call the blur reduction on the xl2546 but you can active it on the xl2540 too
Y U can turn it off
Depend about the person, using stobe (dyac) have pro and cons so you need try in first place.
BlurBoss
Post by BlurBoss » 17 Dec 2018, 14:00
Thinking about buying BenQ XL2540 or BenQ XL2546 too, but I'm unable to find description of what the differences besides 240 Hz DyAc support on XL2546. Can't find description of how image looks on 240Hz DyAc too. Are there any trade offs?
BenQ XL2546, i9-9900K @ 5.0 GHz, RTX 2080 Ti, 32GB (2 x 16GB) 3200 MHz CL14 RAM, Asrock Z390 Phantom Gaming-ITX/ac.
Falkentyne
Post by Falkentyne » 26 Dec 2018, 11:32
LummyTum wrote:So I was gonna get a BenQ XL2540 but it's out of stock in my region, the BenQ XL2546 isn't out of stock in my region and they cost the same.
I wanted to know...
The only thing I know is that the XL2540 apparently supports AMD Freesync, if Benq Blur Reduction is disabled in the service menu (disabled by default, not available in the OSD).
The XL2546 does not seem to support AMD Freesync even if DyAc is forced off--need others to confirm or not.
