Hey guys,
Been trying to tweak my monitor by turning on blur reduction. Here's what I've done:
1. Turned on blur reduction.
2. Used ICC profile for XL2420z@120hz
3. Created a custom resolution in Nvidia Control Panels with 1920x1080@120hz and VT 1502.
4. Used Blue Reduction Calibration Utility to set Persistence to 2 and Crosstalk Area to Earliest.
My problem is this: when I navigate to System -> Information through the on-screen monitor menu, it shows my Current Resolution as "1920x1080@60". Even though my windows settings clearly state 120hz. If I use the pre-made 1920x1080@144 resolution, it shows correctly as "1920x1080@144". Am I missing something? Thanks in advance.https://inro.in/showbox/ https://inro.in/mobdro/ https://inro.in/tutuapp/
BenQ XL2411z On screen menu information shows 60hz????
Re: BenQ XL2411z On screen menu information shows 60hz????
The firmware might be getting confused by the VT tweak. Do you get 120Hz? That's easy to verify, just go to testufo or play a game with vsync and see if it caps out at 120FPS.
