Hi,
I have two monitors, one xl2411z and one xl2546, but it feels like the 2411z is more sharp.
Anyone know if there is a way to force more than 10 the sharpness by using the factory menu?
Force more sharpness on 2546
Re: Force more sharpness on 2546
Question,MagneticDev wrote:Hi,
Is your problem sharpness, or is it strobe crosstalk?
The higher the Hz, the more strobing reaches limitations of the LCD panel, so one good test is to use a lower Hz, such as the 182 Hz custom timings that are available for the XL2546 via the use of a large vertical total (that puts more time between refresh cycles to finish pixel transitions).
I know,
But I talk about sharpness only.
I think when you set sharpness 10 on the 2411z, it's more crisp.
Do you know if there is a way to force more sharp?
No, there is no way to do so.MagneticDev wrote:I know,
In games, you can use ReShade and activate the lumasharpen shader.
