Detected a potentially supported monitor
PostPosted: 13 Feb 2019, 17:20
by denizevrim
I got a 2080 rtx and a xl2411z which are connected through an adapter. The gpu and adapter are connected via dp cable, which is connected to the monitor through a dvi cable.
This is the message I'm getting when opening blur buster: https://imgur.com/a/8A751b1
This is the adapter: https://www.amazon.de/gp/product/B00Q31 ... UTF8&psc=1
I'm getting 144hz fully, however since I can't turn up the brightness without the utility I'm stuck with this dimness.
Any help is appreciated, thanks in advance!
Re: Detected a potentially supported monitor
PostPosted: 13 Feb 2019, 17:56
Due to the way the adaptor cannot relay DDC/CI commands.
There's no way make Blur Busters Strobe Utility work through any DisplayPort-to-DualLink-DVI adaptors that I know of.
Try purchasing a HDMI-to-DVI adaptor cable instead. Remember to purchase the correct cable for the correct video direction, that goes from an HDMI output to a DVI input -- basically from your GPU HDMI output to your monitor DVI input -- not vice versa from a DVI output to HDMI input. I've heard of some success reports through that method. However, the odds of it working successfully may be only 50%:50% and I'm not sure which adaptors will work for you.
Alternatively, use the Factory Menu instead of Strobe Utility (much harder):
viewtopic.php?f=13&t=2467
You do lose the easy utility, and it's a bigger hassle, but you can at least adjust everything you used to adjust in Strobe Utility.
PostPosted: 13 Feb 2019, 18:15
by denizevrim
Thanks for the fast response!
I didn't know that an hdmi to dvi adapter gives 144 hz!
I will look for one and post results.
PostPosted: 13 Feb 2019, 19:53
-- Your monitor XL2411Z HDMI input do not support 144Hz.
-- However, your GPU, the 2080 RTX, HDMI output does support 144Hz.
So that's why you can't connect HDMI-to-HDMI like you can with other newer 144Hz monitors.
However, you can connect a GPU HDMI 144Hz output to the monitor's DVI 144Hz input -- via a compatible adaptor.
You just have to be careful to make sure that the HDMI inputs/outputs you plan to use are 144Hz compatible. Avoid using HDMI on the end that isn't 144Hz HDMI compatible.
Be cautious since not all adaptors will be able to pass the DDC/CI signalling between the two connections -- it's a dedicated wire on DVI and HDMI cables but is not part of DisplayPort (that one is a micropacket standard). That's why it's easier to adaptor the DDC/CI with a DVI-HDMI or HDMI-DVI adaptor. That's why if you want Blur Busters Strobe Utility, you're likely to have more success with HDMI->DVI adaptoring.
PostPosted: 14 Feb 2019, 04:07
by denizevrim
I assume that these kind of small adaptors won't do the job. But I will buy and try this one:
https://www.amazon.de/HDMI-DVI-Adapter- ... B000WKKY40
