BENQ XL2456 Ghosting Trail?
th4click
Post by th4click » 02 Mar 2019, 12:45
Hi everyone i've been lurking blur busters forum for couple of months now and makes me wonder if is there an input lag if DyAc is on. because i'm a slow shooter and i always struggle aiming enemies on the game. So is there a way to get rid of the small trail on the picture below.
i've tried settings the Vertical totals to 1584 @144hz but there seem to be a frame skipping
Falkentyne
Re: BENQ XL2456 Ghosting Trail?
Post by Falkentyne » 04 Mar 2019, 19:46
Open up the "factory" menu (the one with those big blue windows) and mess around with the "OD Gain" setting. Make sure that AMA is set to "High" *before* doing this.
th4click
Post by th4click » 22 Mar 2019, 20:51
Ok will do thanks for your reply :D
Post by Chief Blur Buster » 23 Mar 2019, 02:16
Yes, you need to make sure that the overdrive is adjusted properly for best AMA quality.
Also, are you sure that is a 144Hz photo at 960 pixels/second? The tiny steps between the UFOs suggest you took that photograph at 240Hz instead of 144Hz.
