Dyac High vs. Premium
Posted: 02 May 2019, 01:03
What's the difference between dyac high and premium and how it affects the 182hz tweak.
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
Just making sure that you're talking about DyAc and not AMA?RealNC wrote:It controls the strength of the pixel overdrive. Lower values result in higher pixel response times and more ghosting. Higher values result in lower pixel response times and more reverse-ghosting. To find the best setting for your monitor, you can test the different settings while viewing this animation:
https://www.testufo.com/ghosting
Use the setting that gives you the clearest image. Which setting is best differs from display to display. On most displays the best setting is usually the middle one. But with BenQ/Zowie displays sometimes the higher settings are best. So test it yourself in the above URL.
