Downsampling with MBR 2420z?
Posted: 16 Apr 2014, 08:00
by writer21
Can it be done? I think I know the answer to this just wanted to be sure.
Re: Downsampling with MBR 2420z?
Posted: 16 Apr 2014, 08:58
writer21 wrote:Can it be done? I think I know the answer to this just wanted to be sure.
The answer would be the same as:
http://forums.blurbusters.com/viewtopic.php?f=2&t=619
Posted: 16 Apr 2014, 09:22
by masterotaku
That other topic made me remember about downsampling, so I've been messing with it since yesterday. With my XL2411Z, I could successfully downsample at 2560x1440 up to 75Hz. At 80Hz or more, the image was displayed correctly when creating that custom resolution, but then it wasn't listed, as if I didn't create it.
And then I created a 2880x1620 resolution at 60Hz. 65Hz already gave me an out of range error. I should give it more time, but I just wanted to report my results right now.
Edit: same timings as the 1080p resolution for each frequency I listed in my thread:
http://forums.blurbusters.com/viewtopic.php?f=13&t=560
I should update that thread with downsampling information, but I'll wait until I get the most out of my monitor
Posted: 16 Apr 2014, 09:33
masterotaku wrote:At 80Hz or more, the image was displayed correctly when creating that custom resolution, but then it wasn't listed, as if I didn't create it.
For those reading this, make sure you patch the dotclock with the ToastyX clock patcher --
http://www.monitortests.com
(masterotaku -- I noticed you already did this)
Posted: 16 Apr 2014, 09:34
by masterotaku
It is already patched. It's something I always do after installing new Nvidia drivers
