PM sent
Sorry, this is so confusing to me.
I did used to use MS Dos back in the day, so I'm no stranger to the command line (Heck I used to use a C64).
But new languages..well...they don't come easy to me
Also to clarify my edit of my last post, I noticed that after editing the sources.list file to add the universe multiverse words, after I *REBOOTED* the computer and rebooted back, it acted like nothing had ever been changed. So I have no idea where the packages it had downloaded the first time were even saved.
Do I have to do everything at once, with the monitor actually already plugged into the laptop?
If so, I need to find a way to put the patch file and the V4 firmware file (which is currently on the ROOT folder of the USB drive) onto the Ubuntu disk, somehow. I don't want to wipe my OS to actually install Ubuntu. So where exactly was it saving the downloaded packages to?
*Edit again*
I am reading Bishis post on page 5, but it doesn't explain a few things:
Where is the flashrom folder?
How do you even get the (in this case, 2720Z V4 firmware) to be SEEN in Ubuntu?
Where am I supposed to put it ?
The instructions say "make sure your firmware is in the same folder as the flashrom folder"
That's nice and all, but HOW do you get your firmware into the same folder as the flashrom folder if you can't even FIND the flashrom folder while you're in windows (browsing the USB flash drive?)
I was able to run flashrom (after installing the packages the first time) as well as an i2c command, but I don't know where or how to access the firmware file at all. I named it 2720Z_V4.BIN.
Since the monitor wasn't hooked to the laptop, I restarted, and everything I downloaded was completely gone, even the SOURCES.LIST file had the edit removed.......
And I need to clarify again:
***Make sure the bin filename you use below matches the downloaded file and place it in the flashrom folder before running the following
How do you do this if there is no flashrom folder in the first place? o.o
You can't access windows from Ubuntu if you boot in "Try Ubuntu now" mode...
My Skype name is the same as my username here. I'm sure I'll have V4 firmware in no time if I can figure out what's going on
