Need help with setup utility
Re: Need help with setup utility
Post by Chief Blur Buster » 15 May 2014, 14:58
thizito wrote:I bought mstar isp tool from aliexpress, mentioned here before by some users but not the 'original' Chief said.
We no longer recommend the specific aliexpress unit as that one is extremely difficult to work properly (in fact, the aliexpress unit is apparently harder than the new hardware-free Linux method). The one pictured from cart100 is easier. The aliexpress unit doesn't successfully upgrade via VGA.
To help you along:
1. Go into Service Menu, then enable "DVI HPD", save the setting.
2. Put monitor in standby mode. (I'd unplug the monitor for a few second, plug it in)
3. Don't plug your computer into the monitor, keep it in standby. Use a different screen/monitor for the computer for now. Make sure the monitor you are upgrading is completely black and off with only the power button illuminated (standby mode).
4. Connect aliexpress unit via DVI cable to the monitor.
5. Follow the upgrade instructions.
