I am not entirely sure what's going on here, however I have run the upgrade using the MSTAR ISP tool.
My monitor reports it is on V002-20131209, so I assume it has updated.
When I try to load the blurbusters utility however I get this:
I ran the update a few times. DDC/CI is enabled, AMD CCC detects the display (http://entirely.pro/img/1401912891-PG3l.jpg) and the drivers are installed, I tried another DVI cable, and I am not in service menu mode.
The only issue I can think of is that there was an issue during the update or something on Windows is the problem, when I did the update (from here http://www.blurbusters.com/benq/diy-fir ... q-z-series) at step 11 I got a notice saying "program files not ready" but then it appeared to be fine.
Any help or suggestions would be great! Thank you
Issue with v2 upgrade [now fixed]
Re: Issue with v2 upgrade [now fixed]
If your monitor says V2, the upgrade succeeded.
However, the computer is able to communicate to the monitor over the DDC/CI line.
-- Try to you reboot your monitor: Unplug your monitor and plug it in again.
-- Also, did you exit the monitor's burn-in mode?
Let me know if this works!
