Benq XL2411 Strobe utility work over dvi, dont work over HDMI, will it work over DP to DVI adapter?
Yes. strobe worked fine on my old DVI connection, but since my new card dont have dvi, I had to use hdmi and found out that I cant use it. Unsupported monitor/unable to initialize DDC. Since I dont have other choice, Ill have to get an DP to dvi adapter. Will strobe utility work over that thing?
Re: Benq XL2411 Strobe utility work over dvi, dont work over HDMI, will it work over DP to DVI adapter?
Update: Strobe utility started working over hdmi by itself for some reason, so problem kinda solved...
