Wrong Lod Bias - Damaged I/O System - End of Input ANOMALY lalggers Sekt Era
All Unidentified Forum Objects go in this area! Any fun alien talk goes in this U.F.O. Abduction Lounge, even topics other than monitors or computers. Introduce yourself!
1000WATT
Re: Wrong Lod Bias - Damaged I/O System - End of Input ANOMALY lalggers Sekt Era
Post by 1000WATT » 06 Nov 2024, 14:19
Z3CrosS wrote:
06 Nov 2024, 03:33
Its not a blame, you sound like a victim of modern consumer reality, you even not understand in what you post, i will explain
Poor people are definitely experts in things they don't have money for :lol: :lol:
AudAmerica
Post by AudAmerica » 10 Nov 2024, 01:52
After watching your video, I feel relieved....because you didn't fix it at all.... :D :D :D
Yagami
Post by Yagami » 10 Nov 2024, 15:56
So the problem is that my $5 license key infected my CPU and made it dumb? If I replace the CPU with a new one (boxed), I will lose my Windows activation, but my computer will work properly again, is that right?
Post by Slender » 10 Nov 2024, 17:34
Yagami wrote:
10 Nov 2024, 15:56
if i/o damaged - yes.
but he say that "not work", cuz ofc new all brand new, lol.
themagic
Post by themagic » 11 Nov 2024, 04:14
Yagami wrote:
10 Nov 2024, 15:56
I think that all this is just bullshit about license key...
i have 3 laptops here. 2x HP and 1x Asus...they are not rly for gaming and performance sucks but with Asus one i get 120fps in valorant at low :lol:
but that not the topic...
all this 3 notebooks was buy here in germany and the Asus from computer shop hear near in town. all come with OEM_DM channel license activation/key which is tied to motherboards and can't be reused/copied to other motherboards/hardware like the retails ones. One of the HP notebooks i still don't and never touched or reinstalled and it is still running with original windows 11 home from day 1 since delivery and was preinstalled/activated....
but guess what ? no matter which notebook...shit is still happen literally exact the same way...hitreg/desync and feel of disadvantage only like on my desktop PC with 300fps.
all this I/O damage bullshit and license talk is nonsense.
nothing infected your PC.
if you change CPU then you don't lose your activation.
there exist PC and Notebooks which are shipped with OEM_DM channel. If you have such System...then everything good (download windows from microsoft and enjoy) and don't need to buy retail keys which is only purpose that you can reuse/activate them on different motherboard/builds (that only reason why they cost more)....that all you need to know about license keys.
Z3CrosS
Post by Z3CrosS » 13 Nov 2024, 05:18
Yagami wrote:
10 Nov 2024, 15:56
No, the key is bound for motherboard. OS configure whole hardware. If you dont know how works keys (if you think that the needed only for to remove transparent words on screen) and you need perfect PC, you buy only retail Windows package from Microsoft directly.
Z3CrosS
Post by Z3CrosS » 13 Nov 2024, 05:42
Slender wrote:
06 Nov 2024, 03:15
I'm ready to swear that my friend with a laptop at 144hz, pirated system, works perfectly in terms of input lag and graphics than my pc 13700k 3070ti 360hz. I still don't see the connection between the official usb stick and the system that gives there microsoft via mct.
If the system damage was caused by a pirated system image, it would mean that the original system image would restore the system to a perfect state, but this is not the case.
I don't understand how a pirated key can break the input-output system.
Are we talking about physical damage or software damage?
You said that you solved the problem. Did you buy new equipment?
Yes, indeed. Rebooting, reinstalling, changing anything related to gpu/mon affects the picture and smoothness. Restarting the gpu driver via restart64.exe literally changes the feel of the cursor for some time.
the person changed the thermal paste on the gpu and caused these problems, but we don't know what else he did. Maybe he damaged the cable / display port / pci port / something else.
Maybe with the wrong installation of the gpu (for example, he did it with the power supply on) and because of this something in the pc was damaged.
In any case, if something broke in the pc I (and I think you too) want to know what exactly went wrong and find irrefutable evidence where 0 is the system that does not work properly and 1 where it works as it should work.
If something on my CPU/GPU/Motherboard/RAM isn't working as it should, I want to know for sure, and feelings have no proof here, even though it is the basic feeling of using a PC. Example for me, im associate increased boot time on this pc with graphic degradation, because both things started in same time. (I'm not 100% sure about this, but this is the only NUMBER I can see).
If the system damage was caused by a pirated system image - Not, it is not, what is damaged is damaged.
It would mean that the original system image would restore the system to a perfect state, but this is not the case - not it is not.
https://devicepartner.microsoft.com/en- ... enuine-kit
Im not suggest to take it in mind, there is no point to bring new expensive puzzle
Yes, indeed. Rebooting, reinstalling, changing anything related to gpu/mon affects the picture and smoothness. Restarting the gpu driver via restart64.exe literally changes the feel of the cursor for some time. - Yes, on PC with these symptoms, if you dissasemble all, install clean Windows iso, around ten hours or for a day, PC will work on 50%~ as ideal, with improved picture quality, much better smothness. But it is not ideal anyway. And all will return with some short time. Noticeable for eyes degraded picture quality after 5-10 hours depends of many cases. - This is a sign that there is faults within GPU's i/o system or/and main PC i/o system, something with caches/memory mapping as minimum.
If something on my CPU/GPU/Motherboard/RAM isn't working as it should, I want to know for sure, and feelings have no proof here, even though it is the basic feeling of using a PC. Example for me, im associate increased boot time on this pc with graphic degradation, because both things started in same time. - You cannot physically say what exaclty is damaged, only in your case you see the damage source - its your GPU - and this GPU has a big chance being damaged. In my videos and people posts, i included all different people cases after PC is permanent degraded. Dominating of these cases are some manipulations with GPU.
You said that you want to understand what is provide it. You saw with your own eyes that your GPU from another PC with these symptoms is isnta fucked up your old 6y pirated system straight after GPU change. So you see this exact moment, and its you to decide what happened (its your hardware anyway). What is damaged? PCH/CPU + big chances that GPU is too.
What is damaged your new PC from the start you have to think about it yourself, or maybe you bought whole PC or components from *hit vendor - it could be returned as new. Malfunctionning monitor hypotetically can to provide damage, because it has influence over GPU -> Main PC (PCH/CPU) -> Registers, Physical adresess, memory mappingg + in the same time whole PC configuere any connected devices = that's called two side communication with Monitor.
You want to figuere out, all already figuered out. Everything can provide damage to the system from Ram to keyboard. Your test was one of many with gpus and its cost 1k$, now for example imagine what you are asking, a man who will be building hardware for to directly break it, i mean he achieved to build perfect PC, after he will buy used gpu to break it? And after and again? Interesting for which reason that will be? For people who buy 5$ keys or for those who buy cheap things from unknown shops for points/sales? And feedback from it? Thank you and 5$ as maximum for support?))) There is zero point of spendings for these kinda "tests" and if he do that for some reason he would end up here anyway, because already all was tested. People with whom i spoke and who shared unique exact moments - everything can damage system (even overheating while you play AAA game without FPS lock). These is nothing to prove because all is proven long ago already.
And there is still be a people who continue to *uck in eyes like themagic: nothing infected your PC. - Man here already described that GPU broke his system, and man still continue to *uck in eyes, like there is nothing happened. And thats thier way of life, i dont care how people see things and here im not who is asking for help, for me here is all clear like a day and i dont have any issues to fix, and im not owe here anything to anyone, in fact you owe me and in the same time when i decided to publish videos i was perfectly aware that i will get nothing for my huge work, because at the end i figuered that around 85% of people or maybe more who have these kind of inconveniences are all with same mentality, but there are some people who was just unlucky or/and make some mistakes in many cases - these info for them to understand and make a decision after what to do or not do anything.
Z3CrosS
Post by Z3CrosS » 13 Nov 2024, 06:09
Im long ago moved from this issue and dont want to spend my time of speaking about it anymore. I gave all needed information for free for people who need it and for reasons to save your time and brain, not to continue dancing over these old devices anymore, you cannot do anything with that, you have to take it and not bother.
If you desperately want to achieve even one perfect system in your house, and if you have an inspiration and possibility try to:
Buy new 75hz monitor for 250$ (Aoc for example make good monitors), Xbox S - its best console for price tag and connect both to stabilizer (+use wifi), and you will get what you want. And never connect to Xbox any of your used/old devices. On a success you can use Xbox for many reasons: for games + for native DLNA home-media-server.
You have to choose vendors wisely, because these symptoms are always directly point on a human factor faults (users/vendors). There are a lot of used/refurbershed as new on a market, depends of region and its mentality, the life became much smarter and you have to think for each buck you have.
1000WATT
Post by 1000WATT » 13 Nov 2024, 14:38
Post by Slender » 14 Nov 2024, 02:08
stop, but all have same problem right? all have that double cursor / image.
everyone should have the same source. It can't be ram damage / motherboard damage / processor damage / video card damage in same time.
If the problem is widespread, it should be very specific (as in our case) things. Let's say that such a cursor (double) is seen by those who have a broken PC. Those who have a healthy PC see one cursor, without its ghost.
This means that all people have the same specific thing damaged. If you are sure about this (this is your logic) tell me what it is. Exactly what breaks in the PC, what breaks the system?
