Blur Busters Forums
Low latency Keyboards
All Unidentified Forum Objects go in this area! Any fun alien talk goes in this U.F.O. Abduction Lounge, even topics other than monitors or computers.
Re: Low latency Keyboards
Postby sharknice » 23 Apr 2014, 18:17
Alamar wrote:Isn't low-profile keyboard better than mechanical for games? Like Logitech Ultra-Flat, the only problem such keyboard is not anymore produced and clones aren't that good.
Not really. The types of keys don't really make a significant difference and are pretty much just personal preference.
Key rollover is probably the most important feature for games. If it doesn't register all of your key presses you'll have problems. A higher polling rate is good too, but it isn't nearly as important as it is with a mouse.
sharknice
Postby Chief Blur Buster » 23 Apr 2014, 18:42
Yes, strafing diagonally while running, and jumping during a crouch while shooting simultaneously -- that's 6 keys rolled over at once there. Having only 4-key or 5-key rollover will fail that test.
Postby c0re » 28 Apr 2014, 09:49
Samhain wrote:Since there is a low latency mouse threa
I tryed to find topic about low latency mouse and I failed. Where it is?
c0re
Previous
Return to Offtopic Lounge
Who is online
Users browsing this forum: No registered users and 1 guest
cron
