Alienware AW2523HF announced
leesunchoo
Post by leesunchoo » 17 Aug 2022, 19:39
https://www.displayspecifications.com/en/news/a69883d
Rumors were saying that they would be using the same panel as the next Zowie monitor (AUO 360Hz TN) but it appears to be using another panel without any G-Sync module, atleast it looks like that they are using a much better stand than their last monitors!
unlikely_duty
Re: Alienware AW2523HF announced
Post by unlikely_duty » 17 Aug 2022, 23:14
seems to be using a 360hz ips panel from LG. interesting that theyd release another 360hz ips when they already have the aw2521h.
The aw2523hf panel may be similar to the LG 240hz ips found in the S2522HG.
Post by jorimt » 19 Aug 2022, 10:22
FYI on the topic of panel types, TFTCentral keeps a relatively up-to-date database of monitor panels by size here.
lostinpixelation
Post by lostinpixelation » 12 Sep 2022, 13:42
Well got mine today, was a complete disaster, guess it's some kind of B-Stock - I hope at least - (how is that even possible in that short amount of time), high frequent noises/hum, stand was damaged, the display itself was full with dirt and fingerprints - great QC... Requested a replacement unit - let me know if there are any tests you would like to see.
kyube
Post by kyube » 12 Sep 2022, 18:40
lostinpixelation wrote:
12 Sep 2022, 13:42
Could you perhaps get into the service menu and tell us which panel it has? And do some testUFO ghosting tests at 960pps or 1440pps at max refresh rate! Thanks!
lostinpixelation
Post by lostinpixelation » 26 Sep 2022, 07:01
kyube wrote:
12 Sep 2022, 18:40
12 Sep 2022, 13:42
Got the replacement unit today, unfortunately the high frequent noise is also present on this unit - I can't recommend this monitor to anyone who has good hearing unfortunately.
Can't seem to find the service menu (there is only 1 joystick, the usual stuff didn't open the service menu) - if there are any ideas I can test them before sending this unit back for good.
UFO tests (there are some up for this model now in some reviews) are pretty much the same as for the 2521h - no ghost but average motion blur.
kyube
Post by kyube » 26 Sep 2022, 12:35
26 Sep 2022, 07:01
kyube wrote:
12 Sep 2022, 18:40
12 Sep 2022, 13:42
Perhaps turning the monitor off and pressing some combination of joystick clicks (perhaps 3/5 times left/right would do the trick? Cannot find any info on how to enter service menu for Alienware monitors with joysticks, so I guess one would have to bruteforce his way)
The only review I've found that did a horrendous job at pursuit photography (and the only current review) of the AW2523HF is this: https://www.youtube.com/watch?v=fNiLwUBmND8
He did not sync the framerate with this refresh rate and he did not follow the UFO at all, along with improper camera settings.
It is very vague to claim "no ghost but average motion blur", a properly done testUFO or response times measurements tell a different story. If possible, do a pursuit shot of your monitor! Follow Chief's guide on how to set it up properly.
Discorz
VIP Member
Post by Discorz » 26 Sep 2022, 12:54
26 Sep 2022, 07:01
Is it similar to these AW2521H @360Hz shots? viewtopic.php?f=2&t=10150
Tech Nuovo did a common mistake of recording ufo statically. It's called pursuit for a reason. Here is a quick pursuit guide if u are willing to do one: viewtopic.php?p=74863#p74863
kyube
Post by kyube » 06 Oct 2022, 16:32
Discorz wrote:
26 Sep 2022, 12:54
26 Sep 2022, 07:01
Source: r/monitors discord, member DCBF_GGoki
Color gamut, P3 80%
https://cdn.discordapp.com/attachments/ ... 819803.png
Native gamma test
TestUFO (default settings), taken with phone camera
Discorz
VIP Member
Post by Discorz » 10 Oct 2022, 03:52
kyube wrote:
06 Oct 2022, 16:32
Thanks for posting. Looks to be same as concurent 360 IPS panels but can't know for sure (M250HAN03.0, although there are M250HAN03.2, M250HAN03.3 in existence)
