akrios
Post
by akrios » 10 Nov 2023, 21:03
ChrisGG wrote: ↑27 Aug 2023, 07:28
akrios wrote: ↑06 Jun 2023, 22:40
Been going back and forth lately between G-Sync and ULMB 2 trying to decide what I like more, the extra clarity during motion or the consistent smoothness with G-Sync. I get around 200-220fps a lot in Apex when not capped at 300fps in 1440p.
Have you decided? And how would you compare both in APEX Legends? I'm afraid to make the jump on ULMP2 and destroy my eyes.
I put G-Sync on since then and never looked back. With the 300fps cap in Apex and a lot of drops with my 3080 on 1440p the consistent smoothness from G-Sync is something I really enjoy. I can notice a slight increase in motion clarity especially in TDM or something where I hold 300fps more but don't think it's worth it in BR with more FPS drops.
In something like OW2 with high FPS I'd probably go back again and compare both.
Kuscheln_Hammer92
Post
by Kuscheln_Hammer92 » 19 Nov 2023, 02:00
JediBrysen wrote: ↑02 Oct 2023, 16:00
I want to add to this post that I have gotten ULMB 2 to work on an AMD Radeon GPU
How to Open CRU click edit at the top then uncheck "Include if slot available" at the bottom
Hi bud. Were you also able to create a large vertical total at a lower refresh rate for less strobe crosstalk? I have an rx 7900 xt. Should I then get this over the xl2566k since ulmb2 2 on AMD cards is possible? Can you also show test images?
JediBrysen
Post
by JediBrysen » 19 Dec 2023, 23:59
I personally don't use ULMB 2, don't like the increased latency or headaches
CYCLOPSAG
Post
by CYCLOPSAG » 20 Dec 2023, 07:18
thats amazing,
i play siege and it only supports up to 360hz. Do you or anyone know how i can play 540hz on it using CRU?
i tried making the game setting file read only, but it keep crashing
Garumn99
Post
by Garumn99 » 16 Apr 2024, 13:20
Maybe someone can help, i have the 540hz Asus Monitor with ULMB2, you can set it to 360hz or 540hz in NVCP. Now my minimum FPS can go down to 300 and i get 490fps on average in my main game. For best ULMB2 picture should i set Hz in NVCP to 360hz as i dont always reach 540fps or should i keep it at 540hz.
